I received a car top antenna yesterday that I bought from you guys, but I didn't really see an improvement in speed or stability with it. It actually seemed faster without the antenna but that may have been a coincidence. Do you have any tips on locating the antenna and how best to handle the extra wire? We did notice a difference in the speed that seemed to have something to do whether we coiled up the extra wire or not.
Question on proper location for cellular antenna
Hope this helps...
Originally posted by damian View PostI received a car top antenna yesterday that I bought from you guys, but I didn't really see an improvement in speed or stability with it. It actually seemed faster without the antenna but that may have been a coincidence. Do you have any tips on locating the antenna and how best to handle the extra wire? We did notice a difference in the speed that seemed to have something to do whether we coiled up the extra wire or not.
Expected speeds per carrier
Originally posted by damian View PostThe connection goes from very fast to very slow. What sort or low end download speeds should we be seeing with the Sprint connection?
Multiple connections?
I've also had trouble with this connection handling simultaneous requests. Checking email while surfing or downloading will bring the connection to a grinding slowdown. My old connection, which was a satellite connection, was horrible and I was hoping that the Sprint EvDO would be able to handle multiple computers and requests much better than the satellite connection. Is this how the service is supposed to be or do we need to look into the external antenna to improve the quality of the service?
Multiple connection with Sprint EvDO concern
Originally posted by damian View PostI've also had trouble with this connection handling simultaneous requests. Checking email while surfing or downloading will bring the connection to a grinding slowdown. My old connection, which was a satellite connection, was horrible and I was hoping that the Sprint EvDO would be able to handle multiple computers and requests much better than the satellite connection. Is this how the service is supposed to be or do we need to look into the external antenna to improve the quality of the service?
Signal strength indicator in the EvDO router
In the router admin under status I'm seeing all of the bars lit up on connection strength and that does not seem to correspond to connection speed. A few times I've only had maybe 3 bars lit (colored dk blue) and the connection has been fast. Other times they are all lit and the connection is running under 100kbps down.
Received signal strength (RSS)
Originally posted by damian View PostIn the router admin under status I'm seeing all of the bars lit up on connection strength and that does not seem to correspond to connection speed. A few times I've only had maybe 3 bars lit (colored dk blue) and the connection has been fast. Other times they are all lit and the connection is running under 100kbps down.
Anytime
Definitely! No problem! Hope we can solve this for you. Thanks for your patience and appreciating the complexity of debugging RF/Networking issues especially remotely. You should not have a problem using EVDO as your primary. We actually have several customers including some corporations that are actually moving to EVDO for their "satellite" offices since a solid 800-900kbps is not bad at all.
