Connecting dome antenna to a phone?
  • Filter
  • Connecting dome antenna to a phone?
    I need to get just a little bit more of a signal in my house for my cell phone. I saw that there are some dome antennas that I coul connect directly to my phone. Will that work for what I need? I don't want to spent too much money because I only need to get a little bit more of a signal.
    Direct connect Dome antenna.
    This is possible. You may get a little gain, but chances are you probably won't. There is a much better solution, and it's a little bit cheaper. You can get a glass mount antenna that will adhere to a window and directly connect to a phone or an air card. Also remember that you will need the correct adapter to connect from the antenna to the phone/air-card. Here is the link for the glass mount antenna: http://www.rfwel.com/shop/?target=pr...6&cat=7&page=1
    If you have any questions give RfWeL Technical Support a call at 480.218.1877. I hope I answered your question.
