Important things to know about the ZTE
04-03-2007, 03:02 PM
1.) To access the configuration portal of you ZTE router you will need to use the address of https://192.168.1.1. The user name is "admin" and the default password is also admin. You should change this for security purposes.
2.) You will need to make sure that you have enabled both SSL 2.0 and
3.0. To do this you will need to open Explorer, go to TOOLS, then
ADVANCED, scroll all the way to the bottom and select the appropriate bubbles.
3.) You will need to enable the WWAN connection for an EvDO card to function with the router. To do this you will need to login to the configuration portal using the address above. You will need to login using the user name and either the default password if you have not changed it yet, or the password you created. Once in the Configuration portal, look on the left side of the window, there will be a selection named "WAN" Connection. Once in that screen there will be a selection box named "TYPE". In that selection box select "WWAN" it will ask you for a user name and password. You can use anything you want. You will not need to remember these. Make sure anytime you make a change you click "SUBMIT" at the bottom of the page as well as "SAVE" at the top of the page.
4.) The WWAN status does not display EVDO status just bytes downloaded and when connection was established.
5.) Both IE7 and IE6 will work. You will get an error message when using IE7, but it will give you the option to continue to website anyway. Just choose that option.
6.) Mozilla Firefox will not work.
