⌂›Forum›Wireless Communication›Wireless I/O (Input/Output)›Microvision ROV Bluetooth Barcode Scanner
06-06-2008, 02:31 PM
The Simple, Affordable, and Connected ROV Scanner enables price sensitive data collection on virtually any computing platform. With a rich feature set, wide variety of accessories, and a Bluetooth version available, the ROV Scanner is well suited for your application.
ROV Scanner uses Microvision’s MEMS technology. ROV Scanner boasts large, onboard memory and rubberized grip points for comfort and to stay secured in the user’s hand. Whether you’ve never used a bar code scanner before or you’re a seasoned pro, take comfort in knowing ROV Scanner will get the job done and make you look good along the way.
Connect the ROV Scanner to your host platform using Bluetooth, Serial or USB. Instantly bar code enable any application using Scanner Wedge or SerialMagic bar code scanning software. Developers who desire advanced bar code data control can use the SerialMagic API or Microvision SDK.
Check out the Data Sheet Here: ROV_Scanner_Specifications.pdf
Also click here to check out the product page on this as well.
