At&t hspa+
R
rob350
08-23-2011, 03:57 AM
Hey Everyone,
I need to hook an external outdoor antenna to my AT&T USBConnect Force 4G modem, which appears to be an HSPA+ signal. Which frequency does this operate at? It shows 3 different bands that it operates at? Can someone recommend an outdoor antenna for this application, along with the correct cable and connectors for this modem?
Thanks,
Rob
08-25-2011, 01:05 PM
Here is one antenna that would work: http://www.rfwel.com/shop/9dBi-Multi-Band-Omni-Directional-Cellular-Antenna.html
Cable: http://www.rfwel.com/shop/Custom-Built-LMR-400-Ultra-Low-Loss-Coaxial-Cable.html (select n-male/n-male)
Pigtail: Don't see that pigtail in stock which means we probably haven't identified it (or know of whether it even has an external antenna port - does it?). Once we do it would be included here: http://www.rfwel.com/shop/Cellular-datacard-and-Phone-Antenna-Adapter-Cables-Pigtails.html (and if it has an FME-Male end as it normally does you would need an FME-female/N-Female adapter)
