ForumWireless Communication4G LTE DevicesHuawei E8372 Cellular Modem
Pageof 1⌗ Filter ▾
C
cathy
01-11-2021, 12:08 PM
Does the Huawei E8372 have external antenna ports?
Brian
Administrator
01-11-2021, 12:47 PM
The Huawei Modem E8372 has two external TS9 ports.
Huawei E8372 ports
There are different options for signal improvement for this modem. Depending on application (fixed or mobile), signal reception, among other factors, you can improve signal using these sample antenna kit options for the modem:
Note that cable lengths depends on the distance from antenna mount position to your modem location.
You may consider directional antennas for better gain and if you have a clue of where your provider's signal distributions are.
You can also consider this MIMO antenna with TS9 ports to mate with the modem or use two antenna kits for each port.
For custom LTE signal improvement solutions, feel free to contact an RFWEL Signal Improvement specialist.
Betty
01-20-2022, 11:24 PM
Yes, there are two antenna ports at side of the Huawei E8372 4G LTE Wi-Fi wireless modem.
