⌂›Forum›HVAC Wireless Controls›Wireless Thermostats›Troubleshooting XL824 Wi-Fi Connectivity
K
Kyle
04-20-2021, 01:25 PM
I have a Trane XL824 Thermostat (https://shop.rfwel.com/trane-xl824-p...fi-thermostat/) that has been working just fine until today. Right now, the network has a red X and I cannot connect to Wi-Fi. Do I have to get another one? If not, how can I fix this?
04-23-2021, 01:37 PM
Your Trane XL824 Programmable Wi-Fi Thermostat does not connect to Wi-Fi, the red X over the green bars exhibits this.
Network Error
To resolve this, please follow the instructions outlined below.
  1. Check to ensure the thermostat is on a secure Wi-Fi network, it requires a password or security key to connect. Proceed to the second step if it is on a secure network. Otherwise, please connect to a secure network and check if the issue is resolved.
  2. Press Menu > Settings > Network > Connect to Wi-Fi network and select the network you want the thermostat to join. Enter the password for the network. Please note that the thermostat will not connect if the wrong password is entered.
  3. Verify that you are using the correct password since the thermostat may fail to connect because of a wrong password.
  4. If your phone reconnects to the Wi-Fi network, please reboot the thermostat by pressing Menu > Settings > Reboot and attempt to connect to Wi-Fi again once the thermostat is back to its normal screen.
XL824 Menu
In case the thermostat still fails to connect to Wi-Fi, you can enable the hotspot and connect the thermostat to this network. If the thermostat connects at this time, then there is an issue within your network and you will need to contact your Internet Service Provider to confirm whether DHCP is enabled and MAC filtering is disabled.
Contact our Rfwel HVAC experts for additional questions or other Wireless HVAC Control solutions.
