⌂›Forum›HVAC Wireless Controls›Wireless Thermostats›Connecting Honeywell RTH9580WF Thermostat to Ruud System
D
Dianne
10-12-2021, 02:08 PM
I recently had a Ruud RP1430AJ1NA Heat Pump installed. It is unfortunate that my Nest thermostat would not work. I need to access my thermostat via my phone. Will the Honeywell RTH9580WF Wi-Fi Thermostat (https://shop.rfwel.com/honeywell-wi-fi-smart-thermostat.html) work for me? If not, what will?
12-07-2021, 10:34 AM
Yes, the Honeywell RTH9580WF Wi-Fi Smart Thermostat can work for your unit.
The RP series of heat pumps are designed to operate with standard 24 VAC thermostats and air handlers or gas furnaces. Determining wiring designations and feature compatibility of the wireless thermostat is essential. Turn OFF the power supply from the main circuit breaker before proceeding.
Below is the control's wiring diagram;
The wiring should be done by a certified HVAC technician to avoid any injury or damage.
Once the thermostat is connected to Wi-Fi you can register to Total Connect Comfort and control the thermostat at the comfort of your laptop, tablet, or smartphone.
Find more Wi-Fi thermostats here.
For other custom HVAC control solutions, feel free to contact our HVAC experts for assistance or learn more on our HVAC Controls website.
