I have a wireless Mitsubishi Electric MCCH1 Central Controller (https://shop.rfwel.com/mitsubishi-mc...al-controller/) and wireless receiver MIFH1 (https://shop.rfwel.com/redlink-mifh1...terface-cable/) for AC. It will only allow AC for 2 plus hours. I tried still doing setting but it is still 2 hours. Could be clock setting that needs to be set each time but it is not working out. Please help!
Mitsubishi Electric MCCH1 Timer Settings
First, you need to make sure that MCCH1's clock is set correctly to your current time. Confirm if there is a timer set or any programming start/stop time.
To remove the schedule proceed as follows:
1. Press fan and up button at the same time for 5 seconds. You will now be able to go to the settings to make the changes
2. Change setting 138 to 1 to make the control non-programmable
3. Also, make sure you change setting 136 to 0
Once you make these changes via the thermostat, it will not be on the program/schedule.
Here are other HVAC controllers. For other custom HVAC control solutions, feel free to contact our HVAC experts for assistance.
