⌂›Forum›Power Solutions›Lightning Protection›Lightning Protection Options For Antenna Kits
Guest
Guest
02-05-2020, 06:37 AM
Here are two of our popular lightning protection units for device antenna kits:
1. TW-LP-N-J-BHJ TerraWave - Lightning Arrestor 2. LTNG-2400-GDMF Teletronics - Lightning Arrestor
Please note:
1. LTNG-2400-GDMFhas a maximum frequency of 2.5 GHz so this cannot be used for 2.6 GHz (e.g. LTE Band 41) or 3.5 GHz (e.g. CBRS band or LTE band 48) see additional supported 4G LTE Frequency bands here. 2. LTNG-2400-GDMF has N-Male/N-Female ports - this will not work with our standardN-Male/N-Male jumper. You can connect the N-Male end directly to the N-Female antenna port orcontact usfor an N-Male/N-female jumper.
Lightning Protection Devices Comparison Table:
MODELTW-LP-N-J-BHJLTNG-2400-GDMF
Frequency RangeDC - 6 GHzDC - 2.5 GHz
Insertion Loss≤0.7 dB0.04 dB at 900 MHz
0.07 dB at 1900 MHz
0.1 dB at 2.4 GHz
VSWRDC- 6 GHz <1.41:1.1
Impedance50 Ω50 Ω
ConnectorsN-Female (N Jack) to N-Female (N-Jack) BulkheadN-Female to N-Male
Operating Temperature Range-40°F to 185°F
Insulation Resistance≥2000 MΩ
DC Discharge Voltage90 V
Initial Impulse Wave Discharge450-500 V (1KV/μs)
Rated Impulse Wave Discharge20 KA (Wave 8/20 μs) 10 Times (5 Times Each Polarity)20 KA
Ground ConnectionBy Feedthrough or Screw TerminalBy Feedthrough or Screw Terminal
Recommended AWG18 AWG ground wire
BrandTerraWaveTeletronics
03-10-2020, 06:22 AM
