Lightning Protection Options For Antenna Kits
  • Filter
  • Lightning Protection Options For Antenna Kits
    Here are two of our popular lightning protection units for device antenna kits:
    1. TW-LP-N-J-BHJ TerraWave - Lightning Arrestor
    2. LTNG-2400-GDMF Teletronics - Lightning Arrestor
    Please note:
    1. LTNG-2400-GDMF has a maximum frequency of 2.5 GHz so this cannot be used for 2.6 GHz (e.g. LTE Band 41) or 3.5 GHz (e.g. CBRS band or LTE band 48) see additional supported 4G LTE Frequency bands here.
    2. LTNG-2400-GDMF has N-Male/N-Female ports - this will not work with our standard N-Male/N-Male jumper. You can connect the N-Male end directly to the N-Female antenna port or contact us for an N-Male/N-female jumper.
    Lightning Protection Devices Comparison Table:
    MODEL TW-LP-N-J-BHJ LTNG-2400-GDMF
    Frequency Range DC - 6 GHz DC - 2.5 GHz
    Insertion Loss ≤0.7 dB 0.04 dB at 900 MHz
    0.07 dB at 1900 MHz
    0.1 dB at 2.4 GHz
    VSWR DC- 6 GHz <1.4 1:1.1
    Impedance 50 Ω 50 Ω
    Connectors N-Female (N Jack) to N-Female (N-Jack) Bulkhead N-Female to N-Male
    Operating Temperature Range -40°F to 185°F
    Insulation Resistance ≥2000 MΩ
    DC Discharge Voltage 90 V
    Initial Impulse Wave Discharge 450-500 V (1KV/μs)
    Rated Impulse Wave Discharge 20 KA (Wave 8/20 μs) 10 Times (5 Times Each Polarity) 20 KA
    Ground Connection By Feedthrough or Screw Terminal By Feedthrough or Screw Terminal
    Recommended AWG 18 AWG ground wire
    Brand TerraWave Teletronics
