⌂›Forum›HVAC Wireless Controls›HVAC Accessories›Mitsubishi Electric MCCH1 Timer Settings
07-07-2021, 08:36 AM
First, you need to make sure that MCCH1's clock is set correctly to your current time. Confirm if there is a timer set or any programming start/stop time.
To remove the schedule proceed as follows:
1\. Press fan and up button at the same time for 5 seconds. You will now be able to go to the settings to make the changes
2\. Change setting 138 to 1 to make the control non-programmable
3\. Also, make sure you change setting 136 to 0
Once you make these changes via the thermostat, it will not be on the program/schedule.
Here are other HVAC controllers. For other custom HVAC control solutions, feel free to contact our HVAC experts for assistance.
