⌂›Forum›Amplifiers and Repeaters›Cellular Band Amplifiers and High Gain Booster Antennas›Will a Cyfre CA-819 cellular amplifier be a benefit to my performance?
D
dlevy
04-16-2009, 08:55 AM
Running a Verizon Novatel USB-727 EVDO modem with CradlePoint MBR1000 router. Omni external antenna, 5dBi. dBm without antenna: -85dBm, with: -75dBm. Download 700-1500kbps, upload 200-700kbps, ping 90-200. Using Linksys PAP2T with Callcentric for VoIP. Getting occasional jitter. Will a Cyfre CA-819 amplifier improve VoIP performance and ping times?
04-16-2009, 10:28 AM
Your signal strengths are actually pretty good. You may be hitting the jitter/latency limits of EVDO RevA. Amplifier "maybe" — if RSS varies drastically, a 13dBi Yagi like the Wilson Yagi might help. Otherwise you're limited by network.
04-16-2009, 01:26 PM
Clarification: fading doesn't have to take you below receiver sensitivity — just decrease SNR forcing lower modulation. Amplifier improves SNR. If VZW uses 800MHz in your area, leaves won't affect much.
D
dlevy
04-18-2009, 10:06 AM
Thanks Thuor. LTE? Spending $200+ on a maybe is too much financial hardship. Callcentric has great support. Trying to convince my wife the setup works.
C
chiti
04-20-2009, 10:57 AM
LTE is "Long Term Evolution" that Verizon has committed to deploy. My parents in India use Vonage on worse connections and optimizing VoIP settings brought quality to discernible levels.
