Having problems trying to tunnel VPN traffic through a HSDPA connection (works fine through EVDO). Any test results on this or any idea if this is a bug?
Tunneling VPN traffic...
HSDPA VPN Tunneling
Are you trying to access a remote private network using VPN when connected to the ZTE router or are you trying to setup the network that the ZTE is part of for VPN so that a remote client can access it?Hope the difference is clear.
If trying to access a remote network using VPN and HSDPA for WAN then do you know that this works at all independent of the ZTE e.g connect the aircard to a laptop and try to access the network? If this works then don't see why this should be different from any other backhaul method e.g EV-DO or Ethernet.
HSDPA VPN Tunneling
Originally posted by chiti View PostAre you trying to access a remote private network using VPN when connected to the ZTE router or are you trying to setup the network that the ZTE is part of for VPN so that a remote client can access it?Hope the difference is clear.
HSDPA Support on the ZTE BAVO H110 Mobile Router
There might be some real issues with HSDPA on this router. ZTE Apps Engineers looking into this and I will report back when I learn more. For now I would not recommend getting this if primarily need it for HSDPA. The TopGlobal MB8000/MB6000 routers are still our 1st choice for HSDPA and we have a great deals on these here: http://www.rfwel.com/shop/home.php?cat=1KF7RCQ
HSDPA Mobile Routers
The MB6000 also supports HSDPA available here: http://www.rfwel.com/shop/?target=pr...9&cat=1&page=1 as is the MB6800 coming soon ...KF7RCQ
Originally posted by BrockL View PostHaving problems trying to tunnel VPN traffic through a HSDPA connection (works fine through EVDO). Any test results on this or any idea if this is a bug?
VPN on the ZTE H110
Hey John, here is the response I got back from ZTE engineers - looks like this router is quite different from the demo we put under lab trials.
How is VPN passthrough setup with an internal server on the ZTE when using it with EVDO?
Is it possible to forward just GRE protocal 47 (pptp) and IP protocol 50 (IPSec) without forwarding every external inquiry by setting up a DMZ?KF7RCQ
