Had a question on the gain of the internal antenna for the H110 and how we can boost this up since it's not SMA accessible like other routers?
Boosting Gain on the H110
ZTE Bavo H110 output power and antenna gain
The transmit power (or EIRP=Effective Isotropic Radiated Power) of WLAN card in H1XX is 17~18dBm (about 50~63 mW) and antenna gain is about 2dBi. There is no method to add a high gain antenna to this device on the WiFi side; it was designed with a pair of internal antennas only. (The latest version has a dual internal antenna for diversity).
You can still boost the cellular signal using either a high gain directional cellular band antennas such as http://www.rfwel.com/shop/home.php?cat=63 or even better use cellular amplifiers such as http://www.rfwel.com/shop/home.php?cat=6
If need to increase the coverage of the WLAN radio consider other range extension options such as outlined in this thread: http://www.rfwel.com/forums/showthread.php?t=144Last edited by thuor; 01-13-2007, 03:45 PM.KF7RCQ
Boosting WiFi Router Gain
I agree with thour as indicated above .... it seldom is a good idea to boost WiFi router gain especially for in-biulding scenearios ... maybe for LOS situations e.g trying to get to an outhouse ... plus spread spectrum systems, which 802.11g uses, hate it a lot when one transmitters power is well above all else.
Originally posted by chiti View PostWiFi uses spreadspectrum ... thought that was CDMA for cellularKF7RCQ
