I recently purchased your 2.3 - 2.7 GHz WiMax 12 dBi Omni Antenna and a pigtail adapter for a Clear USB modem. When I plug the antenna into my clear modem (either connection on the modem) the reception actually gets worse than with no antenna plugged in. I checked the resistance between the center contact of the antenna and the outside ground, and there appears to be a dead short between the two contacts. Is this normal, or could the antenna be defective?
I have verified that my cabling is good (also tested with a meter to ensure the continuity was proper from end/end and that there were no shorts in the cable). I tried two different cables just to be sure.
