I'am working for Belgium television in Afrika. We are using a Globesurfer 3 with the mobinil (egypt) network. We are traveling from Egypt to South Afrika.
I have seen your tutorial video on youtube. But i am still having problems configuring the gateway device.
My globesurfer 3 specs:
Telephony;
caller ID: ETSI DTMF
UMTS:
Acces point name: (is this important?)
UMTS connect method: Connect Manually
In case of inactivity, disconnect after:0
Wireless:
wireless: Enabled
At the end of the configuration the device summary says:
Operator: Mobinil
Signal strength: Very good
Connection status: Not connected. Connection failed check your settings.
Connection Type: -
Current connection time: -
I did clicked on connect.
It looks like all my setting are correct but my device tells me connect failed. UMTS
I don't have any idee how to fix it. Is there some piece of info missing in the settings. Or does the cellphone provider (mobinil) still need to activate my sim?
The sim came with a usb simreader and this works fine. I plug in the device and i'am able to surf the internet. But with the Globesurfer its not going.
I hope you can assist me a little bit with this issue. I am looking forward for your reaction.
Telephony;
UMTS:
Wireless:
wireless: Enabled
Operator: Mobinil
Connection Type: -
