Option Globesurfer III workaround if only working on EDGE
  • Filter
  • Option Globesurfer III workaround if only working on EDGE
    We have some units of the Globesurfer III that are only working on EDGE and not UMTS/HSDPA. Here is a workaround to this that we got from Option support:
    Check the default value for the rrc_release_version:
    1) Telnet the GS3 : Start=>Run=>type in cmd, then enter,
    in the window, type in telnet 192.168.1.1
    2) type in user: admin (default ) unless customer changed it.
    3) type in password: admin (default) unless customer changed it.
    3) And then, type in this command => conf print /modem/rrc_release_version
    If the answer for that command is: rrc_release_version(2), then you should put this command and retest:
    1) Telnet the GS3 as before
    2) type in this commands:
    conf set /modem/rrc_release_version 3
    conf reconf 1
    system reboot
