Technical questions on this bluetree product
  • Technical questions on this bluetree product
    Wondering if you can answer some questions on this bluetree product (note plan to use this outside the U.S).
    1) This software is included BlueVue Management Software
    2) Connects wlan 802.11 devices?
    3) The extra antenna is included?
    4) The software can manage all the routers remote...? We can have the monitoring on line? How?
    5) Which cell modem is inside?
    Here are some of the answers to the questions you asked.
    To get the software please download it from BlueTree’s website at: http://www.bluetreewireless.com/support/downloads/softwareand install it on the PC that will be used to configure the modem.
    This is a modem not a router if you wanted to be able to connect via 802.11 you would have to connect it to a 802.11 router via the Ethernet port
    It does not come with a cellular antenna. Remember this is not a Wi-Fi router it’s a cellular modem. If you wanted to increase signal this modem supports two (2) antennas, (with 50Ohm SMA Female Connector)
    BlueTree's BlueVue Management Software supports remote configuration and monitoring over a secure wireless data connection. BlueTree 4600 can easily be configured, monitored and managed using a local cable connection or a remote wireless data connection.
    There are CDMA version and GSM version. Or more specifically CDMA20001x, 1xRTT, EVDO support as well as WCDMA, UMTS, HSDPA, GPRS, EDGE supported version.
