Finally they have released it for sale. The very first expresscard router on the market!!
They are now in stock
Check out the details below!!
Range and Speed:
The MBR1000 leads the Cellular Router market by providing 802.11 ‘N’ technology for superior WLAN distance and bandwidth, and includes Express Card and USB modem ports with a wide list of compatible cellular modems. The MBR1000 supports both EVDO and HSDPA networks.
Continuous Connectivity
The MBR1000 incorporates built-in Cellular Failover capability to provide a best-in-class Enterprise solution that fits the needs of small- and medium-sized businesses. Take your business ‘non-stop’ by adding a cellular modem/router combination to your network backup strategy.
Cellular-Ready
The MBR1000 includes advanced router features such as WPA Protected Setup (WPS) to ensure easy and reliable encryption setup. ‘SGNL’ mode converts the front panel LEDs to signal strength indication – simplifying the placement of cellular modem and WAN antenna, if available.
Features:
* 802.11 ‘N’ for 4x the range and 10x the speed of 802.11g routers
* Two USB ports and 1 Express Card port for Modem Card connectivity
* Works with EVDO, HSDPA cellular networks
* Automatic network failure sense with backup prioritization control of all wireless ports
* WPS Security allows quick configuration and addition of new network nodes
* Also tetherable to wide range of 3G cellular handsets via USB port for emergency backup
* Three external 802.11 antenna for optimum WLAN coverage
* Added firewall prevents unauthorized use of instant or remotely configured networks
Compatibility:
Sprint:
Franklin CDU-550
Franklin CDU-680
LG Musiq
Motorola RAZR V3c
Motorola RAZR2
Motorola Q (Not Q9c)
Novatel U720
Novatel U727
Palm 700w
Palm 700p
Palm 755p
RIM Blackberry 8703e
RIM Blackberry 8830
Samsung A920
Samsung i830
Sanyo Katana 2
Sanyo M1
Sierra Wireless 595U
Sierra Wireless 597E
Verizon:
Kyocera KPC-680
LG VX7200
LG VX8000
Motorola RAZR V3c
Novatel 720U
Novatel V740
Palm 700p
Pantech UM150
AT&T:
AT&T USBConnect 881
Motorola RAZR v3xx
Motorola Q v9h
Option GT Max 3.6 Express
Samsung SGH-A707
Samsung Blackjack
Sierra Wireless AirCard 881U
Applications:
Small Office / Remote Office:
CradlePoint's MBR1000 provides the small office or remote office the ultimate insurance against network outages due to planned and unplanned downtime. Using Cellular networks as a backup with one of the Cellular carriers' 'Router Data Plans', the MBR1000 delivers ultimate flexibility and assurance that mission critical business still gets done.
Remote / Instant Workgroups:
Internet access for businesses that set-up on the road or away from the office is now possible with the MBR1000. Full Ethernet LAN connectivity with 4 LAN ports allows you to set up desktop machines, network drives, and even networked printers for ultimate flexibility. Add to this 802.11 'N' networking and now you can access your network storage in the Construction Trailer or Broadcast Van even while at the jobsite or in the press booth. The MBR1000 gives you a great way to take wireless Internet connectivity to new heights. The added security that comes with every WiPipe router means that you can get access more easily and control your network better that ever before possible.
Emergency Response:
The CradlePoint MBR1000 provides instant 802.11 b/g/n which is perfect for setting up quick response capability in shelters and whever you set up operations. Responders will be able to share vital documents, emails, and mission critical information without waiting for data line drops. Instant access to EVDO and HSDPA networks is via many of the available USB and Express Card modems.
How it Works:
The MBR1000 includes both wired- and wireless WAN interfaces to provide the ultimate flexibility in Internet connectivity for your enterprise. Particularly suited to failover / back up applications, the MBR1000 is a perfect high-performance fail-safe backbone for any business where up-time is critical. Equipped with 2 USB ports and 1 Express Card slot, the unit allows a backup cellular modem connection that can be equipped with a router data plan. With this, cellular charges only apply when you need it – when your wireline is down – allowing your business to be continuously connected. You can even use your data-capable handset, Smartphone, or even a Blackberry as a backup even if you don’t have a modem account set up yet!
In addition, 802.11 ‘n’ technology gives you the increased speed and in-building penetration vs. 802.11 b/g networking.
Features:
* Compliant with IEEE 802.11 b/g/n standards
* Works with a variety of USB and Express Card modems over EVDO, HSDPA cellular networks
* Tetherable to wide range of 3G cellular handsets for emergency backup
* SSA-mode – turns front panel into signal strength indicator
Specifications:
Model #: MBR1000 Mobile Broadband Router
WiFi Standards: IEEE 802.11b/g/n
Network Connections: Ethernet: 1 WAN and 4 LAN ports; Cellular: 2 USB ports and 1 Express Card slot
Firewall: NAT (Network Address Translation) with SPI (Stateful Packet Inspection)
Security: Enable/Disable SSID, Internet Access Control (Services, URL, and MAC)
Encryption: 64/128 bit WEP, WPA/WPA2, and WPA-PSK/WPA2-PSK
Network Applications Support: UPnP, ALG, Email, FTP, Gaming, Remote Desktop, NetMeeting, Telnet and others
Business Applications Support: Multiple and Concurrent IPSEC, L2TP and PPTP VPN pass-through sessions
Platform Compatibility: Windows 98SE/NT/2000/XP/Vista Mac OS X, Linux, and WiFi-enabled devices
Device Management: Via Web Browser (HTTP)
Dimensions (w/o antennas): 8" x 4.75" x 1" (205 mm x 120 mm x 26 mm)
Weight: 14.0 oz.
Certifications: FCC, RoHS
Operating Temp: 0 C to 50 C
Click here to download the data sheet pdf: ds_MBR1000.pdf
Range and Speed:
Cellular-Ready
Features:
Compatibility:
Sprint:
Franklin CDU-550
Franklin CDU-680
LG Musiq
Motorola RAZR V3c
Motorola RAZR2
Novatel U720
Novatel U727
Palm 700w
Palm 700p
Palm 755p
RIM Blackberry 8830
Samsung A920
Samsung i830
Sanyo Katana 2
Sanyo M1
Verizon:
Kyocera KPC-680
LG VX7200
LG VX8000
Motorola RAZR V3c
Novatel 720U
Novatel V740
Palm 700p
Pantech UM150
AT&T:
AT&T USBConnect 881
Motorola RAZR v3xx
Motorola Q v9h
Samsung SGH-A707
Samsung Blackjack
Applications:
Emergency Response:
How it Works:
Features:
Specifications:
Weight: 14.0 oz.
